Nikon Coolpix S220 Accessing the Motherboard
  1. Nikon Coolpix S220 Accessing the Motherboard, Outer Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Nikon Coolpix S220 Accessing the Motherboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Nikon Coolpix S220 Accessing the Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Nikon Coolpix S220 Accessing the Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the rear cover from the camera.
  5. Nikon Coolpix S220 Accessing the Motherboard, LCD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the screen out of its place.
    • You will need to hold the screen slightly above the camera because it will still be attached to the camera by an orange ribbon cable.
  6. Nikon Coolpix S220 Accessing the Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
  7. Nikon Coolpix S220 Accessing the Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly pull the screen from the camera.
  8. Nikon Coolpix S220 Accessing the Motherboard, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
  9. Nikon Coolpix S220 Accessing the Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up silver LCD base plate
  10. Nikon Coolpix S220 Accessing the Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix S220 Accessing the Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
    • Slide the button panel ribbon cable out of its socket on the motherboard.
Shauna
crwdns2935283:004/05/11crwdne2935283:0
798 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-32, Maness Spring 2011 crwdns2935289:0Cal Poly, Team 12-32, Maness Spring 2011crwdne2935289:0
CPSU-MANESS-S11S12G32
It would be nice to have a guide for replacing the flash capacitor.
danwat1234 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,810
