This guide will show how to access the motherboard which will give you the ability to remove the lens and flash.
Remove the two 2.8 mm screws on the left side of the camera.
Remove the four 2.8 mm screws on the right side of the camera.
Remove the three 4.1 mm screws on the bottom of the camera.
Gently lift the rear cover from the camera.
Gently lift the screen out of its place.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
Slowly pull the screen from the camera.
Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
Slide the button panel ribbon cable out of its socket on the motherboard.
It would be nice to have a guide for replacing the flash capacitor.
