Nikon Coolpix P90 Flash Bulb Replacement
    1. Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
      • Push the door open, and remove the existing battery with your fingers, per images 2-3.
    1. Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press the button on the side of the body to open the flash compartment.
    2. Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws from inside the compartment.
    3. Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the plastic opening tool along the crack on the side of the flash compartment cover and pry open and detach the cover.
    4. Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips #000 Precision Screwdriver, remove the 4.0 mm screw from the plastic cover.
      • Detach the plastic cover.
    5. Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully remove the flash bulb holder with your fingers.
    6. Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the plastic opening tool, pry the metal bulb frame out of the socket.
    7. Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the plastic stoppers on either side of the metal flash bulb tray.
    8. Nikon Coolpix P90 Flash Bulb Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a soldering iron, desolder each of the wires connected to the light bulb.
      • Be careful! The soldering iron is hot. Do not burn yourself or the device. It should not be applied to the device too long to avoid damaging any of the device components.
      • For a comprehensive guide on desoldering, visit iFixit's Soldering and Desoldering Guide.
Elizabeth Kamine
crwdns2935283:001/22/15crwdne2935283:0
664 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-14, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 20-14, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S20G14
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 1,277
