Nikon Coolpix P510 LCD Replacement
  1. Nikon Coolpix P510 LCD Replacement, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P510 LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
  3. Nikon Coolpix P510 LCD Replacement, LCD Screen Window: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P510 LCD Replacement, LCD Screen Window: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
  4. Nikon Coolpix P510 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P510 LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the four 4mm PH00 Phillips screws out.
  5. Nikon Coolpix P510 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P510 LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to trace around the screen to pop the front and back section apart.
    i would not rate this as easy, you need patience and a steady hand for the replacing of the ribbion cable, it will test your patience and don’t for get to take the protective film on the replacement lens the i didn’t and had to take it apart again
    terry welles - crwdns2934203:0crwdne2934203:0
  6. Nikon Coolpix P510 LCD Replacement, LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P510 LCD Replacement, LCD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the LCD up to get access to the back of it.
  7. Nikon Coolpix P510 LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix P510 LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
  8. Nikon Coolpix P510 LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
    • It may take a little bit of pressure to get the chip off. Be gentle to make sure you don't break the chip.
    A hair dryer (not a heat gun) is good for getting the adhesive loose. Use a playing card under the circuit board to loosen the bond. If its not coming up apply more heat. The board has parts soldered to it so it is not a good idea to bend the board much since this may break component connections.
    One further point. When reinstalling the larger ribbon cable (it has two rows of contacts) make sure the cable is pushed into the connector as far as possible. I used a pocket knife blade edge on the stiff black part to force it into the connector. If it is not installed fully you will see the backlight but no display. Very discouraging..
    Make sure display and window are both clean and dry before reassembly.
    John LaCourse - crwdns2934203:0crwdne2934203:0
Brian Hulsey
crwdns2935283:003/31/15crwdne2935283:0
1.506 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 2-2, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 2-2, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S2G2
Esse LSD tem outro fita preta que conecta pode estar ruim
Leonardo Silva - crwdns2934203:0crwdne2934203:0
Porque a minha não sei se ela é LCD ou esse negócio preto que conecta que tá ruim
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 6,088
