This will show you how to open up the camera and replace the camera flash.
Turn the front of the camera toward you.
On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
Remove the screw
Flip the camera upside down and remove the seven marked screws.
Turn the back of the camera toward you.
Lift the display panel and remove the two marked screws
Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
Before fully opening the camera, identify the two marked ribbon cables
Properly detach the ribbons before proceeding
Remove the five indicated screws that are attached to the metal plate.
Remove the hidden top screw that is attached to the metal plate.
Use a plastic iFixit opening tool to carefully loosen the metal plate.
Remove the metal plate to access the camera's motherboard.
Now you have access to the camera's motherboard
Remove the screw that is located on the left of the view finder.
