Flip the camera upside down so that the side with the serial number is face up.
Pull back the display panel. Orient the panel so that you are able to view the back of it.
Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
Remove the cover that was unscrewed in the last step.
Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
Use a plastic opening tool to pry open the back panel of the display screen.
Carefully unhook the ribbon that attaches the panel to the camera.
Remove the top black panel cover.
Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
Separate the metal portion of the screen from the plastic portion.
Carefully remove the ribbon connector cable from the metal portion of the display.
Remove the display from the rest of the device.
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I can't reconnect the connector on the step 10. Can you help me?
