Nikon Coolpix L840 LCD Screen Replacement
  1. Nikon Coolpix L840 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Extend the screen by grasping the screen and pulling it out.
  2. Nikon Coolpix L840 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four black, 4mm Phillip #000 screws on the corners of the back case of the screen.
    • Unscrew the two black, 2mm Phillips #000 screws on the case of the hinge. (The hinge connects the screen to the body of the camera.)
  3. Nikon Coolpix L840 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L840 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top-half case of the hinge by lifting it off.
    • Remove the bottom-half case of the hinge by lifting it off.
  4. Nikon Coolpix L840 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the back case off of the screen with a metal spludger by slipping the spludger in between the front and back halves of the screen's case and wiggling the spludger forwards and backwards.
  5. Nikon Coolpix L840 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The front cover comes off easily once the back cover is removed in Step 4.
Abraham Lozano
crwdns2935283:004/11/16crwdne2935283:0
610 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-11, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 1-11, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S1G11
crwdns2947412:09crwdne2947412:0
Where would you suggest I buy a replacement screen?
leinbergerc - crwdns2934203:0crwdne2934203:0
Yours must be different than mine,. mine required a separation of a sticky piece from around the screen and then getting it back on the new one in almost perfect alignment as you find out when you start putting it back together. I used a prying tool a very small Phillips screwdriver and a very small torx tool, all of which came in the kit I ordered from easyworldwidetrading (Hong Kong) (ebay) for $64.99 no. 302013683286, but make sure yours is the same Camera, good Luck
Michael Crawford - crwdns2934203:0crwdne2934203:0
PS: Be very careful, the piece's are cheap plastic and will break... Now I gotta find the outside piece... ugh
My LCD screen shows what I am taking a picture of but when I hit the picture viewer button the screen goes black. So do I need to replace the LCD screen or do you think it would be something else?
Megan Norman - crwdns2934203:0crwdne2934203:0
My screen is showing a grainy pic especially red I have tried all I can think off. It goes when I turn color right down but leaves screen looking black and white. I know there’s an easy fix but can’t seem to find it. Any help pls
Harris Nnadi - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,771
