Nikon Coolpix L830 LCD Monitor Replacement
  1. Nikon Coolpix L830 LCD Monitor Replacement, LCD Monitor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head P000 screwdriver to remove the four 3.0 mm Phillips screws on the back of the monitor.
  2. Nikon Coolpix L830 LCD Monitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head P000 screwdriver to remove the two 3.0 mm Phillips screws on the hinge cover.
  3. Nikon Coolpix L830 LCD Monitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L830 LCD Monitor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top hinge cover.
    • The top hinge cover contains screw holes.
    • Remove the bottom hinge cover.
    • The bottom hinge cover contains no screw holes.
  4. Nikon Coolpix L830 LCD Monitor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover of the LCD monitor with your hands or a plastic opening tool.
    • The cover will slide down the hinge, but it will not be completely removed.
  5. Nikon Coolpix L830 LCD Monitor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L830 LCD Monitor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumb to gently pull the small flex ribbon wire connector from its socket.
    • Use your thumb to gently pull the wide flex ribbon wire connector from its socket.
  6. Nikon Coolpix L830 LCD Monitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to remove the front cover of the LCD monitor, allowing the monitor to be completely be released.
  7. Nikon Coolpix L830 LCD Monitor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the old, damaged LCD monitor.
Blake Johnson
crwdns2935283:010/28/16crwdne2935283:0
347 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-4, Williams Fall 2016 crwdns2935289:0Baylor, Team 4-4, Williams Fall 2016crwdne2935289:0
BU-WILLIAMS-F16S4G4
I cant remove two of the screws. Help
jo Hogan - crwdns2934203:0crwdne2934203:0
Très bien pour démonter , mais pour remonter les nappes, notamment la moins large, je n'arrive pas à l'insérer !
Avez vous une technique à me proposer ?
Michel Cassel - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,780
