If the LCD monitor on your Nikon Coolpix L830 is corrupted or completely blank, replacement is necessary. Following these steps will allow you to replace the broken screen with a new one to allow complete monitor functionality to return.
Use a Phillips head P000 screwdriver to remove the four 3.0 mm Phillips screws on the back of the monitor.
Use a Phillips head P000 screwdriver to remove the two 3.0 mm Phillips screws on the hinge cover.
Remove the top hinge cover.
Remove the bottom hinge cover.
Remove the back cover of the LCD monitor with your hands or a plastic opening tool.
Use your thumb to gently pull the small flex ribbon wire connector from its socket.
Use your thumb to gently pull the wide flex ribbon wire connector from its socket.
Use a plastic opening tool to remove the front cover of the LCD monitor, allowing the monitor to be completely be released.
Gently remove the old, damaged LCD monitor.
I cant remove two of the screws. Help
Très bien pour démonter , mais pour remonter les nappes, notamment la moins large, je n'arrive pas à l'insérer !
Avez vous une technique à me proposer ?
