The device ports on a digital camera can be prone to damage that may render them nonfunctional. This guide will lead you through the necessary steps to replace damaged device ports.
Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
Next, remove the screw held on top of the camera above the Nikon logo.
Moving to the bottom of the camera, open the empty battery slot, and locate the 4 screws in the compartment. Begin removing the 4 screws located within.
Using the spudger, begin prying the case from the device, carefully separating the rear housing from the camera assembly. Once the rear housing is separated, the camera's physical buttons will be accessible for replacement.
Remove the front casing around the LCD screen from the camera.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the tweezers shown in the materials list, lift the hinges connecting the two ribbon wires to the camera. The wires will unlatch from the device.
Once the ribbon wires are disconnected, remove the LCD screen from the camera.
Safely store the LCD for reinstallation.
Begin by removing these five screws.
From there, the panel covering the motherboard can be removed.
Using the pointed end of the spudger, lift the hinges that secure these four flex circuits.
Once the flex circuits are removed, the motherboard can be lifted and the device can be accessed for replacement.
Could you explain how the power button is changed? Thank you!!
