Is your flash not lighting up? This guide will show you how to replace the flash from your camera.
Remove two 5 mm Phillips #000 screws below the flash component.
Use blue plastic opening tool to pry open the casing for the flash.
Remove the plastic casing surrounding the flash.
Pull the wires connecting the flash out of the camera.
Unsolder the wires that connect the flash component.
It's not a comment, but where did you obtain the replacement flashbulb?
the heading says no parts required. but I think i need a new flashbulb? any idea what the type is or where to buy it ?
I can't get into bulb
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a> n advmd vdsm vs ds m
