This is a guide to remove the power button. It is a simple task that can be done after removing the outer case of the camera.
Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
Remove the panel containing the power and shutter button.
