Nikon Coolpix L330 Image Sensor Replacement
  1. Nikon Coolpix L330 Image Sensor Replacement, Back Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement, Back Housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement, Back Housing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
    Note:
    There are 3 locking cam-lugs along the top edge of the back plate. These slot over the top of matching very delicate moulded catches. Carefully lift and lever this top edge first.
    Chris Balchin - crwdns2934203:0crwdne2934203:0
  3. Nikon Coolpix L330 Image Sensor Replacement, LCD Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement, LCD Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tips of your fingers into the space between the screen and back-plate.
    • Gently lift the screen up and out of the frame.
    • The screen is still held by a flexible display cable, therefore only lift the screen 0.5'' out of the back-plate.
  4. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the screen so that the display cable forms a hinge with the backplate.
    • Rotate the display 180 degrees so that it faces you.
  5. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The display cable has a ZIF (zero insertion force) connector on the end. This has a tab that has to be pushed out before the cable can be safely removed.
    • Using a plastic opening tool or fingernail, pop up the black clip holding the display cable. This will release the cable.
    • Slide the display cable out of the connector.
    • The display cable can be damaged due to excessive bending, therefore avoid putting unnecessary strain on it.
  6. Nikon Coolpix L330 Image Sensor Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the silver back-plate with a PH000 screw head.
    • Two 1.5x2.5mm screws on the left side.
    • One 1.5x2.5mm screw on the right side.
  7. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The marked red box contains a highly charged capacitor. Check the charge using a voltmeter and discharge it first before continuing. Discharge capacitor guide.
    • Remove the screws holding the motherboard with a PH000 screw head.
    Err, I don’t think that marked capacitor will hold much charge, though that’s not to say you can’t discharge the flash capacitor as described. The flash capacitor itself will be a large cylindrical component, probably somewhere close by underneath, on the other end of two of those soldered wires.
    Philip Le Riche - crwdns2934203:0crwdne2934203:0
  8. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool or fingernail, pop up the black clips holding the ribbon cables. This will release the cables.
    • Slide the ribbon cables out of the connectors.
  9. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black sticker covering the electrical connections.
    • Desolder the eight wires from the motherboard.
  10. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into the marked position. Push the tool towards the right to release the clip.
    • Using a thumb and forefinger, push the plastic cover up until it is at a 45 degree angle.
    • Pull the cover back and up to release it.
  11. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motherboard is still held in place by soldered connections.
    • Carefully desolder the connections .
    • The front cover has been removed in this picture, however the procedure is still the same.
  12. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard by lifting it directly up.
  13. Nikon Coolpix L330 Image Sensor Replacement, Image Sensor: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement, Image Sensor: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 1.5x2.5mm screws using a PH000 screw head.
  14. Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L330 Image Sensor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 1.5x1.75mm screws holding the lens in place using a PH000 screw head.
    • Lift the image sensor up and out of the bracket.
Rajeev
crwdns2935283:002/09/16crwdne2935283:0
623 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-10, Cagle Spring 2016 crwdns2935289:0USF Tampa, Team 2-10, Cagle Spring 2016crwdne2935289:0
USFT-CAGLE-S16S2G10
In Step 11, there is one board right? I need that board. May I know where to purchase that board?
CJ Ramki - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 918
