Nikon Coolpix L330 Front Housing Replacement
  1. Nikon Coolpix L330 Front Housing Replacement, Back Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Front Housing Replacement, Back Housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Front Housing Replacement, Back Housing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
  3. Nikon Coolpix L330 Front Housing Replacement, Front Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 1.5x2.5mm screws in the battery housing using a PH000 screw head.
  4. Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.5x2.5mm screws below the flash unit using a PH000 screw head.
  5. Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black tape covering the electrical connections.
    • Remove the 1.5x2.5mm screw using a PH000 screw head.
    • Desolder the six marked wires.
    • The screen has been removed as well as the back-plate in this step, however they need not be removed to replace the front housing.
  6. Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool between the front housing and inner frame.
    • Lever the tool to slide the front housing forward.
  7. Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix L330 Front Housing Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the fingers of one hand on the inner frame and the other hand around the lens barrel.
    • Pull the front housing away from the inner frame.
Rajeev
crwdns2935283:002/09/16crwdne2935283:0
623 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-10, Cagle Spring 2016 crwdns2935289:0USF Tampa, Team 2-10, Cagle Spring 2016crwdne2935289:0
USFT-CAGLE-S16S2G10
crwdns2942667:0crwdne2942667:0 1,145
