This guide will help walk you through how to replace the LCD screen in you Nikon Coolpix L320
Flip the camera over to reveal the card/battery door.
Slide the button to the unlocked position and the door should pop open.
Take out the old batteries.
Look at the yellow sticker inside of the the battery compartment. You'll see the symbol for the direction the new battery should face when replaced.
Use a JIS screwdriver to remove seven screws from the frame of camera.
Use an opening tool or spudger to separate the front and back of the camera.
Use a JIS screwdriver to remove the screws connecting the LCD to the motherboard.
Gently flip the LCD over to reveal a ribbon cable connected to the motherboard.
Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector. Then, you can safely pull the cable out.
Remove the LCD screen from the camera.
