Use this guide to replace the LCD.
Clearly visible damage to the LCD. It did not even light up.
Remove the screw from the right side.
Remove the visible screw from the left side.
Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers...
Remove the three screws from the bottom.
Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
After the splitting of the case, the LCD is imediately visible.
Flip the black clasp up by using fingernails or the opening tool. No big force is required. Remove the old LCD.
Here is the new screen, note the blue tab. This is the screen protector, remove it after installation.
Reassemble in reverse order. Hopefully your results will be the same as for me.
