This guide will walk you through the necessary steps to access and remove the LCD screen in the Nikon Coolpix E5700.
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
Open the battery door.
Remove two Phillips screws (3.4 mm) located on the left side of the screen.
Remove two Phillips screws (3.4 mm) located on the right side of the screens.
Remove the Phillips screw on the top right side of the screen.
Carefully unplug the grey bundle of wires in the white housing.
Carefully unplug the small pink and wires in the grey housing.
Remove the two Phillips screws on the left side of the screen.
Remove the metal bar on the left side of the screen.
Remove the screen from the front plastic housing.
