Nikon Coolpix B700 Button Assembly Replacement
  1. Nikon Coolpix B700 Button Assembly Replacement, Back Frame Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
  8. Nikon Coolpix B700 Button Assembly Replacement, Button Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the corner under the power button up.
    • While at the same time pushing the selector knob back.
  9. Nikon Coolpix B700 Button Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This should remove the entire assembly from the camera housing.
Carlos Salgado
crwdns2935283:002/27/19crwdne2935283:0
1.456 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team S4-G5, Hingst Spring 2019 crwdns2935289:0Purdue University Northwest, Team S4-G5, Hingst Spring 2019crwdne2935289:0
PNW-HINGST-S19S4G5
crwdns2942667:0crwdne2942667:0 580
