Nikon Coolpix AW130 LCD Screen Replacement
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the yellow battery/charger compartment tab up using your thumb nail.
    This yellow tab spring broken, how I can repair
    Surendra kumar - crwdns2934203:0crwdne2934203:0
    From where I can get this yellow tab, and how I can replace
  4. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
    Start with a metal spuge from the buckle on the lens-side and work your way from there.
    Its not necessary to remove the whole thing - cause the side on the other buckle tends to break.
    Daniel Bardua - crwdns2934203:0crwdne2934203:0
  8. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
    In the case of my camera, I had to move the plat that says “EAC…” to the side. Underneath was another small Philips screw that I had to remove before I could take off the back panel
    marcelzarrouk - crwdns2934203:0crwdne2934203:0
  9. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the back cover from the camera body.
    Hi, do you have a photo of the back panel but inside, my camera it's cracked in the GPS. Pleaseeeeee
    Gon - crwdns2934203:0crwdne2934203:0
    Merci Tutoriel parfait
    Patrick M
    Patrick Malot - crwdns2934203:0crwdne2934203:0
    The back cover is connected to the main board with two flexible flat cables (FFC). The connectors on the board have lids that lock the cables, so first lift the lids with a plastic tip, then tear the cable with no force aut of the connector.
    Christoph Kunz - crwdns2934203:0crwdne2934203:0
    bonjour , pour ma part le capot ne se retire pas , il semble encore retenu au niveau de la vis centrale du capot inferieur alors que j'ai retiré toute les vis !!! merci de m'eclairer
    gregory bernard - crwdns2934203:0crwdne2934203:0
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
Lauren Stepp
crwdns2935283:001/29/16crwdne2935283:0
1,251 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-4, Virtue Spring 2016 crwdns2935289:0Western Carolina University, Team 1-4, Virtue Spring 2016crwdne2935289:0
WCU-VIRTUE-S16S1G4
crwdns2947412:08crwdne2947412:0
Hi.
Where can you buy a replacement screen?
Ben - crwdns2934203:0crwdne2934203:0
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - crwdns2934203:0crwdne2934203:0
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - crwdns2934203:0crwdne2934203:0
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - crwdns2934203:0crwdne2934203:0
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - crwdns2934203:0crwdne2934203:0
What appears to be the most difficult step —Step 7 —has its critical parts skipped over: how to carefully remove the top cover from its glued surfaces without breaking it. What tool is used? Where does one start the process? Are there particularly vulnerable sections where caution should be used to avoid breaking the cover?
Also not included are the instructions for replacing the top cover and making sure it stays in place. If it is re-glued, what type of glue is used?
Other than that, the instructions are clear and beautifully illustrated.
Peter Jursik - crwdns2934203:0crwdne2934203:0
Mas falta vocês dizerem onde se compra uma tela nova , ou usada e outras peças , seja do que for
Cari - crwdns2934203:0crwdne2934203:0
Mesmo assim obrigado por tudo
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 3,263
