Without the LCD screen, you cannot preview your nifty vacation photos. If this screen is cracked, the waterproof qualities of the Nikon may be sacrificed. Allowing water to infiltrate into the body can cause for additional problems.
            Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
            You should feel the door begin to loosen. Carefully pull the hatch open.
            Push the yellow battery/charger compartment tab up using your thumb nail.
            After pressing the yellow tab, the battery should loosen.
            Slowly pull the battery completely out.
            Using the T5 Torx screwdriver, remove all four 4mm screws.
            Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
            Remove the upper cover (connected by glue) and unscrew the single Philips screw.
            Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
            Carefully remove the back cover from the camera body.
            Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
            Two screws are located on the right.
            The remaining screws are hidden behind a connector ribbon on the left.
            Pull the LCD screen from the plastic frame after removing all of the screws.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
crwdns2947412:08crwdne2947412:0
Hi.
Where can you buy a replacement screen?
Hi.
my contact is josem6073@gmail.com
Thank you .
Please add Torx T5 screwdriver at the tool needed, required at step 5
Hi.
my contact is cpapacon@gmail.com
Thank you .
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
