Nikon Coolpix AW130 Battery Door Replacement
  1. Nikon Coolpix AW130 Battery Door Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 Battery Door Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the yellow battery/charger compartment tab up using your thumb nail.
    This yellow tab spring broken, how I can repair
    Surendra kumar - crwdns2934203:0crwdne2934203:0
    From where I can get this yellow tab, and how I can replace
  4. Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 Battery Door Replacement, Battery Door: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
  6. Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the metal spudger, carefully pry on the plastic plate.
    • The plastic plate should begin to loosen. Completely remove it from the camera body.
  7. Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the battery door. Near the hinge, a pair of screws should now be exposed.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
  8. Nikon Coolpix AW130 Battery Door Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery door away from the camera body.
Lauren Stepp
crwdns2935283:001/29/16crwdne2935283:0
1 251 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-4, Virtue Spring 2016 crwdns2935289:0Western Carolina University, Team 1-4, Virtue Spring 2016crwdne2935289:0
WCU-VIRTUE-S16S1G4
Where can I purchase the battery cover?
Thanh Tran - crwdns2934203:0crwdne2934203:0
Where can I buy the AW130 battery door?
Jose - crwdns2934203:0crwdne2934203:0
I’m trying to replace the battery door. I removed the 2 bottom screws and loosened the plate as in Steps 5 and 6. How do I remove the plate without breaking it?
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Marianne Chaffin Strickland - crwdns2934203:0crwdne2934203:0
Need web site to order battery door?
Connie Mossor - crwdns2934203:0crwdne2934203:0
The spring that holds the yellow tab over the battery is apparently broken/loose on my camera, and was wondering if there is a solution without replacing the camera or using an external battery charger?
Brady Mattsson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,472
