Nikon Coolpix A900 Monitor Replacement
  1. Nikon Coolpix A900 Monitor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. Nikon Coolpix A900 Monitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
    Good addition of different conditions of the camera (camera is dirty)
    Brandon - crwdns2934203:0crwdne2934203:0
  3. Nikon Coolpix A900 Monitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. Nikon Coolpix A900 Monitor Replacement, Rear Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement, Rear Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement, Rear Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. Nikon Coolpix A900 Monitor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. Nikon Coolpix A900 Monitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
    After dropping the camera image with small apertures appears
    D.Osei - crwdns2934203:0crwdne2934203:0
  7. Nikon Coolpix A900 Monitor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black 2.5 mm screws from the monitor bracket.
    Is there anywhere I can buy a replacement screw for this part? I have lost one of these screws
    Dylan Feeney - crwdns2934203:0crwdne2934203:0
  8. Nikon Coolpix A900 Monitor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. Nikon Coolpix A900 Monitor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. Nikon Coolpix A900 Monitor Replacement, Monitor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement, Monitor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement, Monitor: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set the rear case screen down.
    • Remove the two 2.5 mm black Phillips #00 screws.
  11. Nikon Coolpix A900 Monitor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix A900 Monitor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the rear case from the monitor assembly.
    • Make sure that the ribbon cable does not snag on the rear case when removing it.
    Hello. Excellent help. Where can I get a new screen for my Nikon A900 when the screen glass is broken and the screen is not clear, please?
    Timo Nieminen - crwdns2934203:0crwdne2934203:0
Andres Aronstam
crwdns2935283:009/17/19crwdne2935283:0
759 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S22-G3, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S22-G3, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S22G3
Where did you get a new monitor for your camera?
photower - crwdns2934203:0crwdne2934203:0
Bonjour superbe étape par étape ou puis je trouver l’écran LCD du NIKON A900 je ne le trouve pas ! merci de votre retour !
et un grand merci à des personnes comme vous qui nous aide nous pauvre novice !!!
Laurent Farrugia - crwdns2934203:0crwdne2934203:0
This is excellent but where would you get a new 3” monitor?
Panders McMulluon - crwdns2934203:0crwdne2934203:0
Have you tried AliExpress or Ebay?
photower -
crwdns2942667:0crwdne2942667:0 1,316
