This installation guide will help you replace the motherboard of your Nikon Coolpix 4600. Before getting to the motherboard of the camera. You will need to remove the rear and front cases.9084 to follow the steps.
            Locate the six screws on the exterior of the camera. There will be two 3.3 mm screws on the bottom and two 5.25 mm screws either side.
            Using a Phillips 00 screwdriver, remove all of the six screws.
            Gently separate the front and back casing by prying the two sides open with your hands. DO NOT separate them fully, as it could damage internal components.
            Examine the connection between the ribbon cable and the motherboard closely. Identify the two grey tabs on each side of the connecting bracket.
            Slide the grey tabs toward the bottom of the camera to release the ribbon cable. Gently disconnect the ribbon cable from the motherboard.
            Once the ribbon cable is disconnected, you can now carefully separate the back case from the front case.
            With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
            Insert plastic tool under the screen and gently pry up the left side of the screen until the glue seal is broken.
            Locate the orange ribbon cable and two wires (red and white) attached to the motherboard.
            Lift up on the black clamp and pull out data cable.
            The screen should now be completely free from the camera.
            Locate and remove the four 4.25 mm screws on the motherboard using a Phillips 00 screw driver.
            Remove the ribbon cable on the top right of the motherboard. To remove the cable, slide the two grey tabs, located on both sides, towards the top of the camera and gently pull the cable out.
            Turning the camera to the left and tilting it up, look at the left end of the motherboard to locate the grey bracket.
            Twist the grey bracket counter clockwise to remove it from the silver LCD bracket.
            Using a Phillips 00 screwdriver, remove the 4.25 mm screw on bottom left edge of the LCD bracket.
            Lift off the LCD bracket and slip the grey bracket through the LCD bracket. The LCD bracket should now be completely removed.
            Desolder the wire (both black and red) from the motherboard.
            Remove the orange ribbon cable. This is done by sliding each side of the lock bar toward the center of the camera. Gently pull on the ribbon cable to remove.
            Gently peel back the black tape on the bottom, middle of the motherboard. Underneath you will find a screw.
            Remove the 4.25 mm screw with a Phillips 00 screwdriver.
            Gently pull the motherboard away from the lens.
            Flip the camera over.
            Connecting the motherboard to the front case are seven wires.
            Desolder the seven wires.
