crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Nikon Coolpix 3200crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Nikon Coolpix 3200 Teardown, Nikon Coolpix 3200 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a small Philips screwdriver to remove the screws from the base of the camera.
  2. Nikon Coolpix 3200 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a small Philips screwdriver to remove the screws from the side of the camera where the computer lead is.
  3. Nikon Coolpix 3200 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a small Philips screwdriver to remove the two screws from the side of the camera where the card reader is.
  4. Nikon Coolpix 3200 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry apart the outer casing. A gray plastic threaded piece (used to attach camera to a tripod) will fall out.
  5. Nikon Coolpix 3200 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two silver screws that connect the circuit board to the outer front casing.
  6. Nikon Coolpix 3200 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry apart the front outer casing from the circuit board. The camera will now be in three pieces.
  7. Nikon Coolpix 3200 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix 3200 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the connecting strip on the circuit board which connects it to the back outer casing.
  8. Nikon Coolpix 3200 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix 3200 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips screwdriver to remove the two screws next to the computer port and the brass screw on the circuit board.
  9. Nikon Coolpix 3200 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix 3200 Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to unscrew the three screws that connect the outer lens rim to the front casing.
  10. Nikon Coolpix 3200 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix 3200 Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips screwdriver to remove the three screws that hold the flash cover to the outer front casing.
  11. Nikon Coolpix 3200 Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the lid of the battery compartment and use a Philips screwdriver to remove the two screws at the bottom.
  12. Nikon Coolpix 3200 Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to unscrew the two screws that connect the inside battery casing to the front of the outer casing.
  13. Nikon Coolpix 3200 Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the battery casing from the inside of the outer front casing. The circuit board, battery casing, and front outer casing will be attached by a connecting strip along with red and black wires.
  14. Nikon Coolpix 3200 Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use scissors to cut the red and black wires away from the battery points of contact.
  15. Nikon Coolpix 3200 Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the connecting strip away from the circuit board to separate it from the front casing.
  16. Nikon Coolpix 3200 Teardown: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips screwdriver to unscrew the two screws that connect the photo button to the outer front casing.
  17. Nikon Coolpix 3200 Teardown: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly press on the photo button and this component will pop out.
  18. Nikon Coolpix 3200 Teardown: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix 3200 Teardown: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a scalpel to pry apart the metal inner part of the button from the plastic outer piece.
  19. Nikon Coolpix 3200 Teardown: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon Coolpix 3200 Teardown: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernails to peel the outer rim from the front casing.
    • Pull the connecting strip out of the circuit board to separate it from the LCD screen.
    • Use your fingernails to pry apart the back metal piece of the screen (covered by a black plastic film) from the front section of the screen.
  20. Nikon Coolpix 3200 Teardown: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry apart the back black piece and front white piece of the screen. Inside the screen there are four sheets of plastic: one opaque, two mirrored, and one thicker plastic sheet which has a foil piece attached to it.
    • Use a hammer and chisel to separate the lens piece of the camera from the circuit board.
    • Use your fingernails to pry off the motor, motor cover, and flash piece from the lens piece of the camera.
Milly Whitehead
crwdns2935283:003/09/10crwdne2935283:0
47 crwdns2915208:0crwdne2915208:0
Oh, and then just do everything in reverse to put it back together again? That hammer and chisel bit bothers me a bit.
mrs_prolo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 6,348
