Nikon COOLPIX S610c Rear Casing Replacement
  1. Nikon COOLPIX S610c Rear Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c Rear Casing Replacement, Rear Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Rear Casing Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
Kevin Backers
crwdns2935283:001/26/12crwdne2935283:0
304 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-5, Regan Winter 2012 crwdns2935289:0Cal Poly, Team 9-5, Regan Winter 2012crwdne2935289:0
CPSU-REGAN-W12S9G5
crwdns2942667:0crwdne2942667:0 981
