Nikon COOLPIX S610c Lens Assembly Replacement
    1. Nikon COOLPIX S610c Lens Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • On the bottom right of the camera, locate the battery flap switch.
    2. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Move this switch to the right so the battery flap can flip open.
    3. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
    1. Nikon COOLPIX S610c Lens Assembly Replacement, Rear Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 3x3mm screws attached to the rear casing.
    2. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The panel can be identified by the wifi logo on its upper half on the camera's side.
      • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
    3. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry the panel off from the bottom using your fingernail.
    4. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 3x2mm screw underneath the panel near the top of the camera.
    5. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 4x3mm on the opposite side near the selector wheel.
      • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
    6. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the back panel away from the body of the camera, using the space you just opened up.
      • Be careful not to damage the ribbon cable on the opposite end of the camera.
      • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
    7. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
      • The center connector is detached by flipping the black latch up and away from the center of the camera.
      • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
    1. Nikon COOLPIX S610c Lens Assembly Replacement, Front Casing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 3x3mm screws that attach the front casing to the bottom.
    2. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
    3. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the back panel off the motherboard.
      • Be careful not to damage the ribbon cable that attaches the mother board to the rear panel.
    4. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
      • Note that the white ribbon connector latch flips away from the ribbon cable.
    5. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the final 4x3mm screw at the top of the camera near the lens.
    6. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the front casing away from the body of the camera.
      • Be careful not to damage the wires that attach the front panel to the motherboard.
      • Short the leads on the capacitor near the flash to avoid a nasty shock when separating the casing from the body.
    7. Nikon COOLPIX S610c Lens Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the three 3x2mm screws that attach the cables to the front casing.
    1. Nikon COOLPIX S610c Lens Assembly Replacement, Lens Assembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX S610c Lens Assembly Replacement, Lens Assembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry up the ribbon connector that connects the ribbon cable to the lens assembly.
      • Take note that the ribbon connector pulls away from the ribbon.
Kevin Backers
crwdns2935283:001/26/12crwdne2935283:0
304 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-5, Regan Winter 2012 crwdns2935289:0Cal Poly, Team 9-5, Regan Winter 2012crwdne2935289:0
CPSU-REGAN-W12S9G5
crwdns2942667:0crwdne2942667:0 1,270
