Nikon COOLPIX P7700 Focusing Screen Replacement
  1. Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
    These 3 screws are longer than the others! Store them separately.
    Tomaz - crwdns2934203:0crwdne2934203:0
    If you fix the p7800, the right down screw is different, its not a countersink, its flush.
    Robert Böhm - crwdns2934203:0crwdne2934203:0
  3. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
    a. Remove plastic plate between main body & LCD screen (where the thumb is in the pic).
    b. Remove one screw (the only one) found behind the plastic plate.
    Kramm K - crwdns2934203:0crwdne2934203:0
    This is the most scary moment as I did not know how to remove the orange flat cable. I would not come off and I broke off a little plastic. Somehow it came off accidentally as I moved the backcover. The cable was later re- inserted with care, from the right towards the left via a very thin slit.
    JY - crwdns2934203:0crwdne2934203:0
    "It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling." Easily put back? Yeah, right (not!). It is actually anything but easy. I managed doing it after several attempts, but it was more by luck than skill. The ribbon is tiny, the contacts even more so and the slot into which the ribbon must be reinserted - I cannot even see it properly. A pair of small tweezers is a must for this step.
  7. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back casing.
    It would be better to lift the little white adhesive tape so that the backcover could be worked on.
    Step 4: I had to remove the blank screw as well..
    Konrad Erhard - crwdns2934203:0crwdne2934203:0
    Hi,
    Thank you for your most professional advice.
    How can I clean the sensor??
    Moshe Pulik - crwdns2934203:0crwdne2934203:0
  8. Nikon COOLPIX P7700 Focusing Screen Replacement, Focusing Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
  9. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal sheet from the camera.
    • It is okay to remove the orange ribbon from the camera.
  10. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 4.3 mm silver screws located on the ends of the chip using the Phillips #00 screwdriver.
  11. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4.3 mm silver screws on the far right side of the camera using the Phillips #00 screwdriver.
  12. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and detach connector from board as shown.
  13. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the board from the camera to locate lens opening
  14. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4.3 mm screws from the metal sheet using the Phillips #00 screwdriver.
  15. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the metal sheet up and out of the camera.
  16. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the reflective lens.
  17. Nikon COOLPIX P7700 Focusing Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lens from the camera.
Dustin Wahl
crwdns2935283:003/11/15crwdne2935283:0
784 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 2-7, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 2-7, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S2G7
Hey I have a P7700 that shows a lens error and focusing doesn't work.
I took it apart and removed the focus motor and it seems that the focus lens moves as it should but when turning it on the picture will be blurry for a second until the lens error comes up.
What issue is fixed by replacing this focus lens?
Dominik Bessler - crwdns2934203:0crwdne2934203:0
Hello.
Do you have a service procedure to fix the exposure dial in this camera?
Hugo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 2,055
