crwdns2959928:0crwdne2959928:0 ↓This guide showcases how to replace the back casing on a Nikon COOLPX p7700 camera. By following these seven simple steps, you should comfortably be able to remove the casing on the camera to get to the inside.
Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
Remove the side panel.
Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
Begin separating the camera into two parts.
