This guide demonstrates how to remove the image sensor from your Nikon COOLPIX P500 camera.
Remove all the marked screws using a PH00 screwdriver.
Remove the two 3mm screws on the grip.
Remove the two 4mm screws on the side opposite the grip.
Remove the three 4mm screws on the base of the camera.
Remove the four 3mm screws on the base of the camera.
Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
Separate the two parts of the body of the camera slightly.
Release the two cables by lifting up their respective clips with a spudger.
Use a spudger to flip up the cable lock in order to release the ribbon.
Use a PH00 screwdriver to unscrew the four labeled 3mm metal screws on the metal backing.
Remove the four labeled 4mm screws connected to the motherboard.
Remove the metal support.
Desolder the labeled soldering points.
Use a spudger to unlock the labeled connector ribbons.
Disconnect the labeled connector ribbons.
Use a spudger to unlock the two connector ribbons.
Disconnect the two connector ribbons.
Remove the mother board from the camera.
Use a PH00 screwdriver to remove the two 2mm metal screws from the image sensor cover.
Use a spudger to unlock the connector ribbon.
Use a PH00 screwdriver to remove the three 3mm screws holding the image sensor down.
