Nikon COOLPIX P2 WiFi Card Replacement
  1. Nikon COOLPIX P2 WiFi Card Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  12. Nikon COOLPIX P2 WiFi Card Replacement, WiFi Card: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 WiFi Card Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the WiFi card out of the camera.
Joshua Avery
crwdns2935283:001/23/12crwdne2935283:0
31 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-28, Amido Winter 2012 crwdns2935289:0Cal Poly, Team 3-28, Amido Winter 2012crwdne2935289:0
CPSU-AMIDO-W12S3G28
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 995
