Nikon 1 J5 Main PCB Replacement
  1. Nikon 1 J5 Main PCB Replacement, Remove Micro SD card and Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove Micro SD card and Battery
  2. Nikon 1 J5 Main PCB Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2 screws
    • Open plastic LCD connector cover
    • Lift FPC connector latch
    • Detach LCD FPC
  3. Nikon 1 J5 Main PCB Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 4 screws
    • Remove LCD module
  4. Nikon 1 J5 Main PCB Replacement, Back Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING!!! DO NOT TOUCH THESE Solder joints!!! High Voltage up to 300V..
    • Or discharge the flash condenser first, as per "Main PCB replace guide"
    • Remove 3 screws
  5. Nikon 1 J5 Main PCB Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Left side, in connector bay, remove 2 screws.
    • Bottom, reomve 2 screws
    • Right side, remove 1 screw
  6. Nikon 1 J5 Main PCB Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel here and remove 1 screw within.
  7. Nikon 1 J5 Main PCB Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop open back case and remove it from body.
  8. Nikon 1 J5 Main PCB Replacement, Keypad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement, Keypad: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement, Keypad: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect speaker
    • Disconnect keypad FPC
  9. Nikon 1 J5 Main PCB Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push latches from below
    • pop up and remove keypad.
  10. Nikon 1 J5 Main PCB Replacement, Main PCB: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon 1 J5 Main PCB Replacement, Main PCB: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Caution!!! High DC voltage up to 300V
    • Peel tape with an isolated tool (plastic crowbar, plastic tweezers, toothpick etc). DO NOT USE metal tweezers.
    • Use a 2-10kohm 5W resistor to discharge flash condenser, for atleast 10 seconds.
    • Check voltage across 2 points. Make sure it's below 5V DC
  11. Nikon 1 J5 Main PCB Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3 screws
    • Remove 2 screws
    • Remove metal frame.
  12. Nikon 1 J5 Main PCB Replacement, Detach all FPC from main PCB: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flash solenoid and detect
    • Microphones and AF assistant LED
    • Keypad
    • Switches
    • NFC
    • WiFi and Bluetooth, Lens(back)
    • CMOS sensor
    • LCD
  13. Nikon 1 J5 Main PCB Replacement, Desolder Flash Condenser and Tube: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon 1 J5 Main PCB Replacement, Desolder Flash Condenser and Tube: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder Flash Condenser
    • Desolder flash xenon tube
  14. Nikon 1 J5 Main PCB Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon 1 J5 Main PCB Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift top side of main PCB
    • Detach (pull out) lens contacts FPC
  15. Nikon 1 J5 Main PCB Replacement, Remove Main PCBA: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nikon 1 J5 Main PCB Replacement, Remove Main PCBA: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert wisdom here.
Terrance
crwdns2935283:011/17/09crwdne2935283:0
6.671 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 223
