Nike SportWatch GPS Unit Replacement
  1. Nike SportWatch GPS Unit Replacement, GPS Unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
  2. Nike SportWatch GPS Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, gently pull the watch band and front screen apart.
  3. Nike SportWatch GPS Unit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a size #000 Phillips screwdriver, remove the two 2.5 mm screws on the main board.
  4. Nike SportWatch GPS Unit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, use the blue plastic opening tool to pry the main board out of the front panel.
    • Use extreme care when handling the ribbon cable. Avoid twisting or pulling it, as it is delicate and cannot be removed or replaced if damaged.
  5. Nike SportWatch GPS Unit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, remove the orange tape that covers the wire for the GPS.
  6. Nike SportWatch GPS Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the soldering iron, break the wire connecting the GPS to the main board at the connector.
    • When desoldering the GPS wire, set the soldering iron to a moderate heat level (around 350°C/662°F). To prevent damage, avoid prolonged contact with the board. For detailed instructions, refer to the iFixit soldering guide.
  7. Nike SportWatch GPS Unit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble, follow the steps in reverse order. Ensure all connections are secure, screws are tightened evenly, and no ribbon cables are pinched. Once complete, test the watch by powering it on and verifying GPS functionality in an open area.
  8. Nike SportWatch GPS Unit Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After reassembly, power on the watch and perform a GPS test outdoors in a clear area. Wait for the watch to acquire a signal to confirm the successful replacement.
Ian Eichorn
crwdns2935283:010/22/15crwdne2935283:0
678 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 crwdns2935289:0UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015crwdne2935289:0
UMASSD-GULBRANDSEN-F15S5G8
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,946
