Sometimes the back panel of the watch starts to peel or breaks. The steps in this guide will tell you how to remove it so it is ready for replacement.
Face the watch upside down, so that the back of the watch is exposed. Unscrew the six #000 size 5 mm long screws on the back using a size 000 Phillips head screwdriver.
Carefully separate the watch by pulling the band away from the main board.
Pry the black plastic piece above the battery out using a nylon or metal spudger.
Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
After taking the battery out, you will be left with just the band and the backpanel part of the watch.
Where can I find a new watch band?
You can´t. Nike left us alone
So, no way to repair the band then if there's no replacement parts? :(
