Nike+ Sportband Motherboard Replacement
  1. Nike+ Sportband Motherboard Replacement, External Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nike+ Sportband Motherboard Replacement, External Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by removing the Nike+ Sport-band. This gives you access to the plastic housing so you can begin disassembly.
  2. Nike+ Sportband Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nike+ Sportband Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Motherboard Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nike+ Sportband Motherboard Replacement, Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nike+ Sportband Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nike+ Sportband Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing. Make sure not to bend them.
  5. Nike+ Sportband Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nike+ Sportband Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nike+ Sportband Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nike+ Sportband Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
  7. Nike+ Sportband Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
  8. Nike+ Sportband Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nike+ Sportband Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nike+ Sportband Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the metal tweezers to lift the motherboard out of the device.
    • Be careful not to pull or bend the attached wiring.
Alyssa Setnar
crwdns2935283:002/15/16crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
IUPUI, Team 9-9, Wilson Spring 2016 crwdns2935289:0IUPUI, Team 9-9, Wilson Spring 2016crwdne2935289:0
IUPUI-WILSON-S16S9G9
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 332
