Nexus Q NFC Antenna Replacement
  1. Nexus Q NFC Antenna Replacement, Taoglas PU18 Wi-Fi Dual Band Antenna: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze and pull to pop the cap off of the Nexus Q.
  2. Nexus Q NFC Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus Q NFC Antenna Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
    • Once the antenna is disconnected, simply pull it off the outside of the inner dome.
  3. Nexus Q NFC Antenna Replacement, Inner Dome Daughterboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Undo the ZIF connector by prying with a spudger.
  4. Nexus Q NFC Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
  5. Nexus Q NFC Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
  6. Nexus Q NFC Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to disconnect the daughterboard from the ZIF connector.
  7. Nexus Q NFC Antenna Replacement, NFC Antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus Q NFC Antenna Replacement, NFC Antenna: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry out the NFC antenna.
    • The antenna has two layers; be careful not to pry the two layers apart.
Alex Thomas
crwdns2935283:001/31/13crwdne2935283:0
27 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-10, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 7-10, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S7G10
crwdns2942667:0crwdne2942667:0 713
