Nexus Q LED Board Replacement
  1. Nexus Q LED Board Replacement, Ball Bearing Ring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze and pull the cap to remove it from the Nexus Q.
  2. Nexus Q LED Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  3. Nexus Q LED Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Undo the ZIF connector by prying it with a spudger.
  4. Nexus Q LED Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
  5. Nexus Q LED Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
  6. Nexus Q LED Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
  7. Nexus Q LED Board Replacement, LED Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus Q LED Board Replacement, LED Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
    • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
  8. Nexus Q LED Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus Q LED Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the diffuser out, we are exposed to the LED Board.
    • Use a spudger to lightly lift the LED board out.
Taewan Kim
crwdns2935283:001/31/13crwdne2935283:0
22 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-10, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 7-10, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S7G10
crwdns2942667:0crwdne2942667:0 588
