Replace the vibrator on your Nexus 9.
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Disconnect the two ZIF connectors attached to the daughterboards.
Gently pull on the ribbon cable to remove it.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
Use your fingers or a pair of tweezers to remove the bracket.
Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
Use your fingers to lift the daughterboard upward and out of the device.
The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
Use a pair of tweezers to remove the vibrator from the device.
