Nexus 9 Vibrator Daughterboard Replacement
  1. Nexus 9 Vibrator Daughterboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 9 Vibrator Daughterboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 9 Vibrator Daughterboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Vibrator Daughterboard Replacement, Vibrator Daughterboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 Vibrator Daughterboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 9 Vibrator Daughterboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 Vibrator Daughterboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 9 Vibrator Daughterboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 9 Vibrator Daughterboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 Vibrator Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
Geoff Wacker
crwdns2935283:009/30/13crwdne2935283:0
91.723 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 407
