Nexus 4 Plastic Midframe Replacement
crwdns2869540:0crwdne2869540:0: 11.911
3
27
99
11.911
crwdns2955950:0crwdne2955950:0: 38
crwdns2960004:038crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 7
crwdns2959974:07crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 11
crwdns2959982:011crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 2 - 3 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
This guide shows how to remove the motherboard's plastic midframe from the inside of the phone to better access the phone's internal features.
    1. Nexus 4 Plastic Midframe Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 4 Plastic Midframe Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      SIM Card Eject Tool
      $2.99
      • Power off the phone, by long-pressing the power button and touching Power off.
      • Remove the SIM tray using the SIM Card Eject Tool.
      • This step is required in order to remove the back case.
    2. Nexus 4 Plastic Midframe Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      T5 Torx Screwdriver
      $5.49
    3. Nexus 4 Plastic Midframe Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 4 Plastic Midframe Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 4 Plastic Midframe Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
      • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
    1. Nexus 4 Plastic Midframe Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 4 Plastic Midframe Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 1.8 mm Phillips screws holding down the battery connector.
      • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
    2. Nexus 4 Plastic Midframe Replacement, Battery removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 4 Plastic Midframe Replacement, Battery removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Plastic Cards
      $2.99
      • Remove the blue tape that secures the white antenna cable to the battery.
      • Using a spudger, carefully disconnect the white antenna cable.
      • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
      • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
      • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
    1. Nexus 4 Plastic Midframe Replacement, Plastic Midframe: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
      • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
Kaitlyn Jones
crwdns2935283:001/27/13crwdne2935283:0
4.964 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-32, Amido Winter 2013 crwdns2935289:0Cal Poly, Team 3-32, Amido Winter 2013crwdne2935289:0
CPSU-AMIDO-W13S3G32
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 99
crwdns2959996:0crwdne2959996:0 11,911
