Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
Slide the tool along the edge to work the back cover off.
Remove the tape covering the motherboard.
Remove the silver tape holding the white ribbon cables to the battery.
Use a spudger to carefully disconnect the battery connector from the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
Pull the ribbon cables out of the connectors with tweezers or two fingers.
Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
Slowly pull up masking tape by pulling down from the top.
Peel the bottom part of the masking tape off to reveal the ribbon connector.
Pull both camera lenses out of the holes.
Use a spudger to disconnect the two camera lenses from the device.
Carefully lift the black connector to release the cameras.
Pull both camera lenses out of the ribbon connector.
