Nextbook 8 Battery Replacement
  1. Nextbook 8 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nextbook 8 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nextbook 8 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nextbook 8 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nextbook 8 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
crwdns2935229:023crwdne2935229:0
Dylan Wiese
crwdns2935283:003/11/15crwdne2935283:0
1,871 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 5-1, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 5-1, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S5G1
Where can I buy the battery???
scruff67 - crwdns2934203:0crwdne2934203:0
Check Ebay. That's where I'm headed right now.
Tina Carey -
im having connection issues i cant find any wifi period
crusher309 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 42,536
