NexiGo NS32 Trigger Assembly Replacement
crwdns2869540:0crwdne2869540:0: 471
12
56
471
crwdns2955950:0crwdne2955950:0: 3
crwdns2960004:03crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
This is a guide on how to replace the trigger buttons from inside the NexiGo NS32. There are 10 specific steps in this guide that describe how to take the trigger buttons out of the controller. Be careful not to damage any of the internal components.
    1. NexiGo NS32 Trigger Assembly Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient the controller so that it is face down.
    2. NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the eight 9 mm Phillips screws that secure the rear case.
    3. NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the rear case up and off.
      • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
    1. NexiGo NS32 Trigger Assembly Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grip the white battery connector and pull it directly out of its motherboard socket.
      • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
      • Do not pull on the wires.
    2. NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the battery up and out.
      • Take care not to bend or puncture the battery as you remove it.
    1. NexiGo NS32 Trigger Assembly Replacement, Joystick PCB: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement, Joystick PCB: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the three 9 mm Phillips screws that secure the joystick PCB.
    2. NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip up the black ZIF connector locking flap on the left side of the joystick PCB.
      • Pull the ribbon cable directly out of its socket.
    3. NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift out the joystick PCB.
    1. NexiGo NS32 Trigger Assembly Replacement, Trigger Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip up the black ZIF locking flap that secures the trigger assembly ribbon cable.
      • Disconnect the ribbon cable.
    2. NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NexiGo NS32 Trigger Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently lift out the trigger assembly.
Gage_Atx
crwdns2935283:001/29/24crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 18-3, Watkins Spring 2024 crwdns2935289:0Austin Community College, Team 18-3, Watkins Spring 2024crwdne2935289:0
AUSTINCC-WATKINS-S24S18G3
crwdns2936753:030crwdne2936753:0 56
crwdns2959996:0crwdne2959996:0 471
