Newport HT70 Pump Assembly Replacement
  1. Newport HT70 Pump Assembly Replacement, Pump Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the base assembly so that you may access it.
    • Using the #1 Phillips screwdriver, unscrew the four screws (SCR3219P in the photo) and the two screws (SCR3232P) securing the base plate.
  2. Newport HT70 Pump Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The base plate will then come apart from the rest of the device with the pump assembly attached to it, as depicted in the following photo.
    • Inspect pump assembly for any damage or looseness.
  3. Newport HT70 Pump Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If damage is found, replace the pump assembly by removing each tube individually and replacing as needed.
    • You may not need to replace the entire assembly if parts of it are still intact.
Merek McGill
crwdns2935283:004/07/20crwdne2935283:0
520 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 277
