New Speed 26-inch Electric Bike Throttle Replacement
  1. New Speed 26-inch Electric Bike Throttle Replacement, Electric Bike Throttle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3/32" Allen screw from the top of the throttle.
    • When removing the screw, make sure the wrench is well seated to avoid damaging the screw.
    • Make sure that your bike's power is turned off before beginning to disassemble it.
  2. New Speed 26-inch Electric Bike Throttle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5/64" Allen screw from the underside of the throttle.
  3. New Speed 26-inch Electric Bike Throttle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the throttle off of the handlebar.
    • Be careful when removing the throttle. Taking it off too quickly could result in damage to the wiring.
  4. New Speed 26-inch Electric Bike Throttle Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2mm Phillips screws from the back of the control box.
    • Repeat this process for the other side of the control box. 4 screws will be removed in total.
  5. New Speed 26-inch Electric Bike Throttle Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the control box.
  6. New Speed 26-inch Electric Bike Throttle Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 New Speed 26-inch Electric Bike Throttle Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unwrap the cable lining surrounding the throttle cable.
    • Track the throttle cable to the control box.
    • Disconnect the JST-SM connector from the main controller.
    • Take caution while handling these wires. They can be easily damaged.
  7. New Speed 26-inch Electric Bike Throttle Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 New Speed 26-inch Electric Bike Throttle Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut the zip ties found along the frame of the bike.
    • Remove the throttle and its wires from the frame of the bike.
    • Be careful not to cut too close to the wires, as you could risk damaging them or hurting yourself.
To reassemble your device, follow the steps in reverse order.
Ryan Arnold
crwdns2935283:010/06/22crwdne2935283:0
236 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-1, Raign Fall 2022 crwdns2935289:0University of North Texas, Team 2-1, Raign Fall 2022crwdne2935289:0
UNT-RAIGN-F22S2G1
Tengo una bicicleta eléctrica y le deconeste la ruda trasera donde está el motor y cuando la monte intentaba arrancar pero no continuava
Casto - crwdns2934203:0crwdne2934203:0
Elmodelo de mi bicicleta eléctrica es DEEPOWER y tiene la avería que le digo anteriormente
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 1,631
