New Nintendo 3DS XL 2015 Battery Replacement
  1. New Nintendo 3DS XL 2015 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. New Nintendo 3DS XL 2015 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
    My experience indicates that a JIS #1 is more appropriate here.
    John Menden - crwdns2934203:0crwdne2934203:0
    Same here, much more appropriate.
    Jack Wilson -
  3. New Nintendo 3DS XL 2015 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are loosened, pry open the back cover.
    In order to remove the back cover, slide it down towards you and then pry the cover off.
    Jon Fukumoto - crwdns2934203:0crwdne2934203:0
  4. New Nintendo 3DS XL 2015 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
    • Remove the SD card by pressing it in with your thumbnail until it clicks and partially ejects, then pull it out.
    Also you should remove any SD card at this point
    James Grant - crwdns2934203:0crwdne2934203:0
    Does this battery work on a NEW 3DS XL model?
    Froggy The Frog - crwdns2934203:0crwdne2934203:0
    This guide is for the New 3DS XL, which is called the 2015 3DS XL here on iFixit. If you're asking about the 3DS replacement battery advertised in the iFixit store, I believe it works for both new and old models.
    BabblingFishes -
    The battery is the same and will work on both the new and old models
crwdns2935229:033crwdne2935229:0
Kobbe Farwick
crwdns2935283:004/01/15crwdne2935283:0
2,414 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-4, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 24-4, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S24G4
crwdns2935297:030crwdne2935297:0
Bonjour,
Tout d’abord merci pour ces explications claires et précises. Toutefois, je me demandais s’il y avait un endroit où l’on peut trouver une batterie officielle Nintendo ? Après quelque recherches je n’ai malheureusement rien trouvé (et comme la console est vieillissante…)?
Nicolas BARET - crwdns2934203:0crwdne2934203:0
Bonjour Nicolas Si vous voulez une pièce de nintendo, vous devez être en amérique ou au canada car nintendo ne vend des pièces que dans ces pays, je peux vous donner le site Web pour les états-unis et le canada si vous le souhaitez.
Nelson Berrios -
The battery didn't work at all. After replacing the old battery I plugged it in and the charging light would go off after a few seconds. I tried to turn on the 3ds with the new battery in and all that would happen is the blue light would flash for less than a second and the 3ds wouldn't turn on
Youjustjealous - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 29
crwdns2936753:07crwdne2936753:0 147
crwdns2936753:030crwdne2936753:0 860
crwdns2942667:0crwdne2942667:0 24,616
