Netgear WGR614v9 Capacitor Replacement
  1. Netgear WGR614v9 Capacitor Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Capacitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Netgear WGR614v9 Capacitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Capacitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Netgear WGR614v9 Capacitor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Capacitor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Capacitor Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Capacitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Netgear WGR614v9 Capacitor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. Netgear WGR614v9 Capacitor Replacement, Capacitor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Netgear WGR614v9 Capacitor Replacement, Capacitor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the motherboard so that the top is facing up.
    • Set the motherboard on a flat clean surface.
  8. Netgear WGR614v9 Capacitor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Netgear WGR614v9 Capacitor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The capacitor can be found at the location shown.
  9. Netgear WGR614v9 Capacitor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Netgear WGR614v9 Capacitor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the motherboard so that the bottom is facing up.
    • Locate the two soldered contacts of the capacitor.
  10. Netgear WGR614v9 Capacitor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Netgear WGR614v9 Capacitor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Netgear WGR614v9 Capacitor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the motherboard 180 degrees.
    • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
    • Refer to this link for proper de-soldering and soldering techniques.
    • Pull the capacitor from the other side of the circuit board once the solder is liquified.
    • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
Kyle Moore
crwdns2935283:010/03/11crwdne2935283:0
95 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-24, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 21-24, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S21G24
crwdns2935297:011crwdne2935297:0
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,370
