crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Nighthawk AX8 8-Stream AX6000 WiFi Routercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Fold wings down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift each antenna wing up and then fold it down, like how the router was when it was first removed from the box.
  2. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove bottom pads and screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four rubber pads, and then remove the four Torx T10 screws underneath those pads.
    • Note: You will feel a divot underneath the serial number sticker, but there is no hidden screw. You do not need to remove or damage the sticker.
  3. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove antenna wing screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the router over again.
    • Remove the left-most and right-most Torx T7 screws from both antenna wings.
  4. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove bottom plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the router again.
    • Pull the bottom plate upwards to remove it.
  5. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove wire tape: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note: The router's mainboard is no longer secured to the shell, but attempting to remove it could damage the antenna wires and ribbon cable.
    • The antenna and fan wires are secured with tape.
    • Use tweezers to lift each piece of tape off.
  6. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Disconnect antenna wires: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Disconnect antenna wires: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Each antenna is plugged into the mainboard with a simple snap connector.
    • Lift off each snap connector with your fingers or a plastic spudger. It is recommended you label these in order from top to bottom so assembly is easy.
    • The antenna wires are also run through 'teeth' on the board. Pull the wires out of each tooth.
  7. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Disconnect ribbon cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will find a ribbon cable connected to the mainboard in the lower-right corner.
    • Use a thin spudger or fingernail to flip the small black clip up. It does not fold over completely to the left, and do not attempt to force it.
    • Pull the ribbon cable out to the right.
  8. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove mainboard from shell: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the mainboard upwards towards the ethernet ports.
    • Pull the mainboard slightly forwards from the ethernet ports. The board should slide out with ease.
  9. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Disconnect fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the mainboard over so that the heat sink and fan are facing you.
    • Locate the fan connector in the upper-left of the mainboard.
    • Pull the fan connector upwards.
  10. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove heat sink screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the mainboard over again so that the underside is facing you.
    • Use a Torx T10 bit to remove the six screws.
  11. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove the heat sink: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the mainboard over again so the heat sink and fan are facing you. The components will not detach as the mainboard and heat sink are stuck together with thermal pads.
    • You will have to use a fair amount of pressure to remove the heat sink from the mainboard.
    • You will hear a peeling or tearing sound, but this is just the sticky thermal pads releasing from the PCB shields on the mainboard.
  12. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Heat sink and mainboard separated: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the heat sink and mainboard sitting side by side
    • The metal components on the mainboard are PCB shields. These are soldered into place.
    • The thermal pads for the lower two PCB shields are thicker, and sit in a divot in the shield.
    • The thermal pad for the upper PCB shield are thinner, and just touch the shield instead of sitting in a divot.
    • The thermal pad in the middle of the board is only for extra stability.
  13. Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown, Remove fan: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The 55mm fan can be removed from the underside of the heat sink.
    • Flip the heatsink over so that the thermal pads are facing you.
    • Remove the two thermal pads covering the fan screws.
    • Use a Torx T10 bit to remove the fan screws.
Matt Zulawski
crwdns2935283:010/02/17crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 260
