How to remove the plastic housing of the camera to either replace it, or remove it to get to the internals of the camera.
Locate unlock switch on underside of camera and unlock it by sliding it.
Once unlocked, slide the cover out and up to open the battery housing.
Remove all 4 of the 3.0 Volt batteries from the battery housing.
Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
Once the screws are removed use an opening tool to pry back the second plastic mount.
Where can I buy replacement parts like a battery cover for Arlo
Note that under the rubber cover shown in step 6 there is a USB-B port.
You can run the Arlo on a USB adapter as well.
You only need to make a hole in the battery lid or 3D print a new cover.
