This is a step-by-step guide on how to remove the lens assembly PCB board in a Netgear Arlo. Remove the batteries before beginning this guide.
Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
Once the screws are removed use an opening tool to pry back the second plastic mount.
Remove 4 (6mm) large screws with a J00 screwdriver.
Once screws are removed, pull apart the clear housing.
Remove rod from camera cover.
Remove Large ribbon cable first to disconnect front of camera from main body.
Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
Remove smaller ribbon cable from underneath yellow tape.
Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
crwdns2947412:08crwdne2947412:0
toller Tipp! Weiß jemand, wo man die Linse kaufen kann.?
Wo bekomme ich ein neues Gehäuse?
hi I took out the battery befor it was finished downloading new firmware, now there is no connection, no blue light. Can you help or is the camer garbage?
I struggled a bit with the ribbon cable connections, they need to be lifted up from the side the cable enters. They are sort of hinged like a door but lying on its side. Once it is stood up vertically, the cable will pull out. For the longer one I found it was important to lift as much of it up at once otherwise it will break if you lift one end and not the other. Once the cable is reinserted, they can just be pushed back down, same as before, supporting the full length when you do. If one comes off it is possible to push it back onto the hinge but it is very very tricky and took a while.
Where did you get the replacement lens?
