A quick and simple guide for replacing batteries in the Netgear Arlo security camera.
Locate unlock switch on underside of camera and unlock it by sliding it.
Once unlocked, slide the cover out and up to open the battery housing.
Remove all 4 of the 3.0 Volt batteries from the battery housing.
Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
i am having a problem charging my arlo pro device
I am having a problem with one of my cameras not recognizing the batteries. I replace the battery and it says that it’s low. I’ve tried the same battery on another one of my cameras and it has a full life of energy. I am out of warranty but wanted to know if maybe I can take take it somewhere to get fixed and where???
La batterie est carrée modèle qui n’est pas en vente sur le marché
Peut-on l’acheter chez Arlo ?
Remplacement de la batterie sur le modèle Arlo caméra extérieur ou trouver ce modèle de batterie
